[postgis-users] Creating lines from a geometry collection
Birgit Laggner
birgit.laggner at vti.bund.de
Mon Feb 27 00:29:10 PST 2012
Hi David,
I would think working with a subselect would solve your problem:
SELECT
generate_series(1,ST_NumGeometries(geom)) as gid,
geom
FROM (
SELECT
ST_GeomFromEWKB((ST_Dump(ST_Split(g.geom, blade.geom))).geom)
As geom,
FROM
points as blade,
lines as g
WHERE
ST_Intersects(g.geom, blade.geom)
) as sel;
Hope that helps,
Birgit.
Am 25.02.2012 22:01, schrieb David Quinn:
> After re-reading the documentation I realized I missed an example, so
> I figured out what I need to do (in part):
> SELECT
> ST_GeomFromEWKB((ST_Dump(ST_Split(g.geom, blade.geom))).geom) As geom
> FROM
> points as blade,
> lines as g
> WHERE
> This works fine, but I also want to include a column that is an
> identifier. I've tried doing the following:
> SELECT
> ST_GeomFromEWKB((ST_Dump(ST_Split(g.geom, blade.geom))).geom) As geom,
> generate_series(1,ST_NumGeometries((ST_Split(g.geom,
> blade.geom)))) as gid
> FROM
> points as blade,
> lines as g
> WHERE
> While this does generate a series, it starts counting for each line
> that it splits so it is 1,2,3,1,2,1,2,3,4. How can I have a sequential
> GID (or get the total geometry count)?
> -David
> On Sat, Feb 25, 2012 at 2:54 PM, David Quinn <daithiquinn at gmail.com
> <mailto:daithiquinn at gmail.com>> wrote:
> Hello,
> I'm trying to split up a line using points into several smaller
> lines. I'm using ST_Split but I don't understand how to combine
> the returned values into a line. My code is as follows:
> SELECT
> ST_Dump(ST_Split(g.geom, blade.geom)) AS geom
> FROM
> points as blade,
> lines as g
> WHERE
> I've tried using a few different geometry constructors such as
> ST_LineFromMultiPoint() and ST_GeomFromEWKB() to convert what
> ST_Dump() returns to create lines but my syntax/approach is not
> correct. What is the correct approach?
> Thanks,
> David
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120227/58041d56/attachment.html>
