[postgis-users] Creating lines from a geometry collection
David Quinn
daithiquinn at gmail.com
Sat Feb 25 13:01:16 PST 2012
After re-reading the documentation I realized I missed an example, so I
figured out what I need to do (in part):
SELECT
ST_GeomFromEWKB((ST_Dump(ST_Split(g.geom, blade.geom))).geom) As geom
FROM
points as blade,
lines as g
WHERE
ST_Intersects(g.geom, blade.geom)
This works fine, but I also want to include a column that is an identifier.
I've tried doing the following:
SELECT
ST_GeomFromEWKB((ST_Dump(ST_Split(g.geom, blade.geom))).geom) As geom,
generate_series(1,ST_NumGeometries((ST_Split(g.geom, blade.geom)))) as
gid
FROM
points as blade,
lines as g
WHERE
While this does generate a series, it starts counting for each line that it
splits so it is 1,2,3,1,2,1,2,3,4. How can I have a sequential GID (or get
the total geometry count)?
-David
On Sat, Feb 25, 2012 at 2:54 PM, David Quinn <daithiquinn at gmail.com> wrote:
> Hello,
> I'm trying to split up a line using points into several smaller lines. I'm
> using ST_Split but I don't understand how to combine the returned values
> into a line. My code is as follows:
> SELECT
> ST_Dump(ST_Split(g.geom, blade.geom)) AS geom
> FROM
> points as blade,
> lines as g
> WHERE
> I've tried using a few different geometry constructors such as
> ST_LineFromMultiPoint() and ST_GeomFromEWKB() to convert what ST_Dump()
> returns to create lines but my syntax/approach is not correct. What is the
> correct approach?
> Thanks,
> David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120225/ed74a97b/attachment.html>
