[postgis-users] ST_LineToCurve for less than 4 points
Denis Rouzaud denis.rouzaud at gmail.com
Tue Feb 28 07:46:31 PST 2012
I partially agree.
If you look in the doc
http://postgis.refractions.net/documentation/manual-svn/ST_LineToCurve.html
It is written that it should convert to circular strings or curved polygon.
In case of circular strings, you need at least 3 (and not 4) points to
determine the circle, as explained in Stephen's link
http://paulbourke.net/geometry/circlefrom3/
On 02/28/2012 04:32 PM, Paul Ramsey wrote:
> No. This is a misunderstanding of purposes.
> ST_LineToCurve is the inverse of ST_CurveToLine. CurveToLine takes in
> a circular object and linearizes it, turning curves into regular small
> sections of linear arcs to approximate the input shape.
> LineToCurve analyzes an input linestring, looking for the tell-tale
> regularity of linearized arcs and converts them back to real arcs. The
> process can only work with linestrings that have for or more vertices
> to analyze.
> What Denis is looking for is probably something more like
> http://trac.osgeo.org/postgis/ticket/1291
> P.
> On Tue, Feb 28, 2012 at 12:38 AM, Sandro Santilli<strk at keybit.net>  wrote:
>> On Tue, Feb 28, 2012 at 09:36:34AM +0100, Denis Rouzaud wrote:
>>> Hi,
>>> Can someone tells me why ST_LineToCurve needs at least a linestring
>>> of 4 points to be run?
>>> If I have three points, I should be able to create a circularstring, right?
>>> Here the error I have:
>>> SELECT ST_LineToCurve(ST_GeomFromText('LINESTRING(554803.177682475
>>> 145390.853708235,554796.469135702 145401.404724093,554769.634948609
>>> 145404.042478058)'));
>>> ERROR:  pta_desegmentize needs implementation for npoints<  4
>> If I read the message correctly it answers exactly your questions.
>> It "needs implementation". A patch is welcome.
>> --strk;
>>   ,------o-.
>>   |   __/  |    Delivering high quality PostGIS 2.0 !
>>   |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
>>   `-o------'
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120228/5de5f13f/attachment.html>
