[postgis-users] ST_LineToCurve for less than 4 points
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Feb 28 08:06:56 PST 2012
Thanks for the warning.
I won't do it again, I promise ;)
On 02/28/2012 04:57 PM, Leoze Oze wrote:
> Dear Denis,
> you need to be strong to be partially agree with Paul Ramsey. ;)
> Regards.
> On Tue, Feb 28, 2012 at 3:46 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
> I partially agree.
> If you look in the doc
> http://postgis.refractions.net/documentation/manual-svn/ST_LineToCurve.html
> It is written that it should convert to circular strings or curved
> polygon.
> In case of circular strings, you need at least 3 (and not 4)
> points to determine the circle, as explained in Stephen's link
> http://paulbourke.net/geometry/circlefrom3/
> On 02/28/2012 04:32 PM, Paul Ramsey wrote:
>> No. This is a misunderstanding of purposes.
>> ST_LineToCurve is the inverse of ST_CurveToLine. CurveToLine takes in
>> a circular object and linearizes it, turning curves into regular small
>> sections of linear arcs to approximate the input shape.
>> LineToCurve analyzes an input linestring, looking for the tell-tale
>> regularity of linearized arcs and converts them back to real arcs. The
>> process can only work with linestrings that have for or more vertices
>> to analyze.
>> What Denis is looking for is probably something more like
>> http://trac.osgeo.org/postgis/ticket/1291
>> P.
>> On Tue, Feb 28, 2012 at 12:38 AM, Sandro Santilli<strk at keybit.net> <mailto:strk at keybit.net> wrote:
>>> On Tue, Feb 28, 2012 at 09:36:34AM +0100, Denis Rouzaud wrote:
>>>> Hi,
>>>> Can someone tells me why ST_LineToCurve needs at least a linestring
>>>> of 4 points to be run?
>>>> If I have three points, I should be able to create a circularstring, right?
>>>> Here the error I have:
>>>> SELECT ST_LineToCurve(ST_GeomFromText('LINESTRING(554803.177682475
>>>> 145390.853708235,554796.469135702 145401.404724093,554769.634948609
>>>> 145404.042478058)'));
>>>> ERROR: pta_desegmentize needs implementation for npoints< 4
>>> If I read the message correctly it answers exactly your questions.
>>> It "needs implementation". A patch is welcome.
>>> --strk;
>>> ,------o-.
>>> | __/ | Delivering high quality PostGIS 2.0 !
>>> | / 2.0 |http://strk.keybit.net -http://vizzuality.com
>>> `-o------'
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120228/2cd2888b/attachment.html>
