[postgis-users] Transform
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Feb 28 08:27:35 PST 2012
> OK, it seems ST_Transform is working for me, but I'm a bit confused about the
> "raster_columns" table. The original (pre-transform) raster table is a set of 187
> tiles.  In raster_columns 'scale_x', 'scale_y', 'blocksize_x', 'blocksize_y' are all
> defined, and 'same_alignment'=t.
> Then when I run AddRasterConstraints(output_table, 'rast'), these value are
> either null or f.  Do I need to do anything else to use the reprojected data, like
> re-tile it or something?
What if you display their extents (rast::geometry) in OpenJump or another display tool? Do they align properly?
Are the scalex and scaley, just to mention them, identical for every tile?
Pierre
