[postgis-users] Transform
Stephen Crawford
src176 at psu.edu
Tue Feb 28 08:50:31 PST 2012
ScaleX and ScaleY are identical for each tile in the original table, and
are all different in the transformed table, which I guess should make
sense on a transform?
I actually now think my output problem is in GDAL. I have been
outputting AAIGrids which I then use in geoserver. The values are
between 0 and 1, and I think GDAL is auto-detecting the table as int and
giving me all 0. At least I think that is what is happening :-) I will
try the process with another table.
Steve
On 2/28/2012 11:27 AM, Pierre Racine wrote:
>> OK, it seems ST_Transform is working for me, but I'm a bit confused about the
>> "raster_columns" table. The original (pre-transform) raster table is a set of 187
>> tiles. In raster_columns 'scale_x', 'scale_y', 'blocksize_x', 'blocksize_y' are all
>> defined, and 'same_alignment'=t.
>> Then when I run AddRasterConstraints(output_table, 'rast'), these value are
>> either null or f. Do I need to do anything else to use the reprojected data, like
>> re-tile it or something?
> What if you display their extents (rast::geometry) in OpenJump or another display tool? Do they align properly?
> Are the scalex and scaley, just to mention them, identical for every tile?
> Pierre
> postgis-users mailing list
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
src176 at psu.edu
814.865.9905
