[postgis-users] Transform
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Feb 28 08:56:19 PST 2012
Bborie,
Is there any way to force ST_Transform(rast, srid) to produce rasters with a specific, identical alignment?
Or we have to ST_Resample them afterward?
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Stephen Crawford
> Sent: Tuesday, February 28, 2012 11:51 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Transform
> ScaleX and ScaleY are identical for each tile in the original table, and are all
> different in the transformed table, which I guess should make sense on a
> transform?
> I actually now think my output problem is in GDAL. I have been outputting
> AAIGrids which I then use in geoserver. The values are between 0 and 1, and I
> think GDAL is auto-detecting the table as int and giving me all 0. At least I think
> that is what is happening :-) I will try the process with another table.
> Steve
> On 2/28/2012 11:27 AM, Pierre Racine wrote:
> >> OK, it seems ST_Transform is working for me, but I'm a bit confused
> >> about the "raster_columns" table. The original (pre-transform) raster
> >> table is a set of 187 tiles. In raster_columns 'scale_x', 'scale_y',
> >> 'blocksize_x', 'blocksize_y' are all defined, and 'same_alignment'=t.
> >> Then when I run AddRasterConstraints(output_table, 'rast'), these
> >> value are either null or f. Do I need to do anything else to use the
> >> reprojected data, like re-tile it or something?
> > What if you display their extents (rast::geometry) in OpenJump or another
> display tool? Do they align properly?
> > Are the scalex and scaley, just to mention them, identical for every tile?
> > Pierre
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Stephen Crawford
> Center for Environmental Informatics
> The Pennsylvania State University
> src176 at psu.edu
> 814.865.9905
