[postgis-users] how to create a hole in a polygon table?
Robert Buckley
robertdbuckley at yahoo.com
Tue Feb 28 10:04:18 PST 2012
I am trying to create an inner buffer of a polygon geometry table.
Unfortunately this is the only way I can think of which will enable me to make a certain symbol for a polyon layer. The SLD Filter "difference" might do it, but it needs to be nested and i´m not sure if this is possible.
anyway....My polygons need to be symbolized with a thin outline AND an inside Buffer of 3 mm(150m at a scale of 1:50 000)....in essence just an inside ring.
This means I need to first buffer my polygon geometry and then substract the buffer from the original polygon. = ST_Difference (i think!?!)
my attempt created some geometries but not what I was expecting...
create view rrop08.rrop_01_13_innerbuffer AS
SELECT ST_Difference(a.st_buffer, b.the_geom)
FROM rrop08.rrop_01_13_buffer a, rrop08.rrop_01_f b;
rrop08.rrop_01_f = the original polyon
rrop08.rrop_01_13_buffer = the inner buffer
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120228/eff34e12/attachment.html>
