[postgis-users] how to create a hole in a polygon table?
Paul Ramsey pramsey at opengeo.org
Tue Feb 28 10:20:46 PST 2012
Rather than geometry processing, work on your rendering engine. You
can usually achieve an interior band (the classic National Geographic
political boundary, yes?) with a half-brush (rather than a full
circle, use a half-circle), and just ensuring your polygons are
consistently oriented.
P.
On Tue, Feb 28, 2012 at 10:04 AM, Robert Buckley
<robertdbuckley at yahoo.com> wrote:
> Hi,
> I am trying to create an inner buffer of a polygon geometry table.
> Unfortunately this is the only way I can think of which will enable me to
> make a certain symbol for a polyon layer. The SLD Filter "difference" might
> do it, but it needs to be nested and i´m not sure if this is possible.
> anyway....My polygons need to be symbolized with a thin outline AND an
> inside Buffer of 3 mm(150m  at a scale of 1:50 000)....in essence just an
> inside ring.
> This means I need to first buffer my polygon geometry and then substract the
> buffer from the original polygon. = ST_Difference (i think!?!)
> my attempt created some geometries but not what I was expecting...
> create view rrop08.rrop_01_13_innerbuffer AS
> SELECT ST_Difference(a.st_buffer, b.the_geom)
> FROM rrop08.rrop_01_13_buffer a, rrop08.rrop_01_f b;
> rrop08.rrop_01_f  = the original polyon
> rrop08.rrop_01_13_buffer = the inner buffer
> postgis-users mailing list
