[postgis-users] ERROR:function totopogeom() does not exist
Salvatore Larosa-1
s_larosa at libero.it
Wed Feb 29 01:48:14 PST 2012
Hi Sandro
i recompiled again version alpha7 and i get:
*SELECT postgis_full_version():*
"POSTGIS="2.0.0alpha7SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
USE_STATS (core procs from "2.0.0alpha7SVN" need upgrade) (topology procs
from "2.0.0alpha7SVN" need upgrade) (raster procs from "2.0.0alpha7SVN" need
upgrade)"
*SHOW search_path:*
""$user", public, topology"
But now, when run script (strk.demo.sql) i get this:
ERROR: SQL/MM Spatial exception - start node not geometry start point.
CONTEXT: SQL statement "SELECT ST_ChangeEdgeGeom(atopology, rec.edge_id,
snapedge)"
Can i open a ticket for this?
Regards
View this message in context: http://postgis.17.n6.nabble.com/ERROR-function-totopogeom-does-not-exist-tp4529301p4530753.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
