[postgis-users] ERROR:function totopogeom() does not exist
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Feb 29 02:04:05 PST 2012
This in a discussion that is already going on.
http://postgis.refractions.net/pipermail/postgis-users/2012-February/032748.html
I am filling this ticket right now.
Thanks
Denis
On 02/29/2012 10:48 AM, Salvatore Larosa-1 wrote:
> Hi Sandro
> i recompiled again version alpha7 and i get:
> *SELECT postgis_full_version():*
> "POSTGIS="2.0.0alpha7SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> USE_STATS (core procs from "2.0.0alpha7SVN" need upgrade) (topology procs
> from "2.0.0alpha7SVN" need upgrade) (raster procs from "2.0.0alpha7SVN" need
> upgrade)"
> *SHOW search_path:*
> ""$user", public, topology"
> But now, when run script (strk.demo.sql) i get this:
> ERROR: SQL/MM Spatial exception - start node not geometry start point.
> CONTEXT: SQL statement "SELECT ST_ChangeEdgeGeom(atopology, rec.edge_id,
> snapedge)"
> Can i open a ticket for this?
> Regards
> View this message in context: http://postgis.17.n6.nabble.com/ERROR-function-totopogeom-does-not-exist-tp4529301p4530753.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120229/c7cd28a6/attachment.html>
