[postgis-users] Spatial join not finishing
Jorge Gil j.a.lopesgil at tudelft.nl
Wed Feb 29 16:01:10 PST 2012
All,
Problem fixed.
Looking at the results from the Explain tool (thanks Paul!) it showed
that it was taking too long because it was using a sequential id.
I just had to create a spatial index on the geometry of the two tables
to speed it up.
I suspect many other queries I've been doing will take a lot less from
now...
Jorge
On 29/02/2012 23:34, Jorge Gil wrote:
> Dear Paul,
> Thanks for the tip, as you can see I'm a newbie...
> I've run Explain on the query and the result is this:
> UPDATE source.bag_new_buildings as aa SET units=bb.count FROM (SELECT
> cc.gid , count(*)
> from source.bag_new_buildings as cc, source.bag_new_landuse as dd
> where ST_Within(dd.the_geom, cc.the_geom) group by cc.gid) as bb WHERE
> aa.gid=bb.gid;
> "Update on source.bag_new_buildings aa  (cost=0.00..9265800547.24
> rows=211379 width=949)"
> "  ->  Merge Join  (cost=0.00..9265800547.24 rows=211379 width=949)"
> "        Output: aa.gid, aa.pandstatus, aa.bouwjaar, aa.energielab,
> aa.the_geom, aa.area, aa.gf_function, bb.count, aa.ctid, bb.*"
> "        Merge Cond: (bb.gid = aa.gid)"
> "        ->  Subquery Scan on bb  (cost=0.00..9265772098.07
> rows=211379 width=48)"
> "              Output: bb.count, bb.*, bb.gid"
> "              ->  GroupAggregate  (cost=0.00..9265769984.28
> rows=211379 width=4)"
> "                    Output: cc.gid, count(*)"
> "                    ->  Nested Loop  (cost=0.00..9265766615.81
> rows=250936 width=4)"
> "                          Output: cc.gid"
> "                          Join Filter: ((dd.the_geom && cc.the_geom)
> AND _st_within(dd.the_geom, cc.the_geom))"
> "                          ->  Index Scan using bag_new_buildings_pkey
> on source.bag_new_buildings cc  (cost=0.00..24750.04 rows=211379
> width=714)"
> "                                Output: cc.gid, cc.pandstatus,
> cc.bouwjaar, cc.energielab, cc.the_geom, cc.area, cc.gf_function,
> cc.units"
> "                          ->  Materialize  (cost=0.00..5114.21
> rows=165414 width=100)"
> "                                Output: dd.the_geom"
> "                                ->  Seq Scan on
> source.bag_new_landuse dd  (cost=0.00..4287.14 rows=165414 width=100)"
> "        ->  Index Scan using bag_new_buildings_pkey on
> source.bag_new_buildings aa  (cost=0.00..24750.04 rows=211379 width=905)"
> aa.energielab, aa.the_geom, aa.area, aa.gf_function, aa.ctid"
> Just the sub query within the update gives this result:
> SELECT cc.gid , count(*) from source.bag_new_buildings as cc,
> "GroupAggregate  (cost=0.00..9265769984.28 rows=211379 width=4)"
> "  ->  Nested Loop  (cost=0.00..9265766615.81 rows=250936 width=4)"
> "        Output: cc.gid"
> "        Join Filter: ((dd.the_geom && cc.the_geom) AND
> source.bag_new_buildings cc  (cost=0.00..24750.04 rows=211379 width=714)"
> "              Output: cc.gid, cc.pandstatus, cc.bouwjaar,
> cc.energielab, cc.the_geom, cc.area, cc.gf_function, cc.units"
> "        ->  Materialize  (cost=0.00..5114.21 rows=165414 width=100)"
> "              ->  Seq Scan on source.bag_new_landuse dd
> Is this helpful? It looks like these operations are meant to take
> really long.
> Thank you,
> Jorge
> On 29/02/2012 23:15, Paul Ramsey wrote:
>> Without a query plan (explain ... ) there's not much people can do but
>> scratch their chins sagely.
>> P.
>> On Wed, Feb 29, 2012 at 3:11 PM, Jorge Gil<j.a.lopesgil at tudelft.nl>
>> wrote:
>>> Hi everyone,
>>> I've been trying to do a spatial join for a couple of days in
>>> different ways
>>> and it never seems to finish. I've done something identical before
>>> in a much
>>> larger set of the same data and it worked after a few hours.
>>> I have a polygons (buildings) table with 150,000 records and a
>>> points (land
>>> use) table with 170,000 records. I want to calculate how many points
>>> are
>>> within each building and add that total to the column 'units' in the
>>> buildings table. The query I run is this:
>>> UPDATE buildings as aa SET units=bb.count FROM (SELECT cc.gid ,
>>> count(*)
>>> from buildings as cc, landuse as dd
>>> aa.gid=bb.gid;
>>> I also try to create a separate table with the results of the join
>>> before
>>> doing the update, but the first step also fails.
>>> Am I doing something wrong? Is there a simple trick that makes this
>>> more
>>> efficient?
>>> Thank you,
>>> Jorge
>>> Jorge Gil
>>> PhD Candidate
>>> TU Delft / Faculty of Architecture
>>> Department of Urbanism
>>> Chair of Spatial Planning and Strategy
>>> Julianalaan 134
>>> 2628 BL Delft
>>> P.O. Box 5043
>>> 2600 GA Delft
>>> The Netherlands
>>> www.tudelft.nl
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Jorge Gil
PhD Candidate
Julianalaan 134
2628 BL Delft
P.O. Box 5043
2600 GA Delft
The Netherlands
www.tudelft.nl
