[postgis-users] Custom Projection
Sean Christopher Conway
seanc at backroadmapbooks.com
Fri Jan 6 09:42:09 PST 2012
Hello, thank you for your reply. Yes, essentially I have done this exact
SQL, but when I export it using quantum gis or FME, i get the following
projection parameters
Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: Greenwich
Angular Unit: Degree
whereas, I would like these parameters:
Geographic Coordinate System: Geographic Coordinate System
Datum: WGS84
Angular Unit: degree
We need it to be like this and are using the following projection to
create it:
GEOGCS["Geographic Coordinate
System",DATUM["WGS84",SPHEROID["WGS84",6378137,298.257223560493],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120106/46d8bc41/attachment.html>
