[postgis-users] Nearest Neighbour Index calculation
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jan 18 08:37:53 PST 2012
Matthias,
Try using the function for the nearest neighbor search:
http://bostongis.com/?content_name=postgis_nearest_neighbor_generic#130
and is should speed things up significantly. So your query in the loop
would look like:
select dist from pgis_fn_nn(start.the_geom, 1.0, 1, 100,
't_harrispoints_reduced', 'start.gid <> gid', 'gid', 'the_geom');
1.0 assumes degrees and should be the maximum distance you want to
search for a nearest neighbor.
100 is the number of increments that you want to divide the search into.
Adjust these values to fit you data.
-Steve
On 1/18/2012 10:21 AM, Matthias Ludwig wrote:
> Hi,
> I want to calculate the Nearest Neighbour Index for statistical interpretation of point data. It simply sums the distances to the first neighbours and devides it through the count.
> create or replace function
> nn()
> returns double precision as $$
> declare
> result double precision := 0;
> id integer;
> count integer;
> begin
> count := (SELECT count(*) FROM t_harrispoints_reduced);
> for id in (SELECT gid FROM t_harrispoints_reduced) loop
> result := result + (
> SELECT ST_Distance(start.the_geom, ende.the_geom) as distance
> FROM t_harrispoints_reduced AS start,
> t_harrispoints_reduced AS ende
> WHERE start.gid = id AND
> start.gid<> ende.gid
> ORDER BY ende.the_geom<-> start.the_geom
> LIMIT 1
> end loop;
> result := result / count;
> return result;
> end
> $$ language 'plpgsql' stable;
> It does the job...but not really fast. For 8000 points it take about 90 seconds. QGIS those the same work in 2-3 seconds. Is it possible to speed this up? Is it possible to prevent the loop?
