[postgis-users] Merging lines - one on another
Matej Mailing mailing at tam.si
Sat Jan 21 12:40:27 PST 2012
Thanks to both of you.
Now I have a query like:
SELECT *
FROM public.my_table AS part_1, public.my_table AS part_2
WHERE ST_SharedPaths(part_2.wkb_geometry_4326,
ST_SnapToGrid(part_1.wkb_geometry_4326, part_2.wkb_geometry_4326, 0.5,
0, 0, 0))
- it seems that ST_Snap(geom, geom, float) doesn't exist at my PostGIS
- is it correctly that I have changed it to ST_SnapToGrid, which also
requires more float parameters?
- it seems also that ST_SharedPath doesn't exist. Did you mean ST_SharedPaths?
When I run this query, I get an error:
ERROR:  function st_sharedpaths(geometry, geometry) does not exist
LINE 3: WHERE ST_SharedPaths(part_2.wkb_geometry_4326, ST_SnapToGrid...
HINT:  No function matches the given name and argument types. You
might need to add explicit type casts.
Do I need some other PostGIS version or am I doing it wrong?
TIA,
Matej
2012/1/21 Sandro Santilli <strk at keybit.net>:
> On Sat, Jan 21, 2012 at 02:19:06PM +0100, Andrea Peri wrote:
>> ST_SharedPath(geom1, ST_Snap(geom1, geom2, 0.5))
> I guess you meant:
>  ST_SharedPath(geom2, ST_Snap(geom1, geom2, 0.5))
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
