[postgis-users] ST_MapAlgebraExpr() Function
Paragon Corporation
lr at pcorp.us
Sun Jan 22 19:47:50 PST 2012
Just tried it on my latest build which is about a week old (a little newer
than the windows build currently on site but much older than when this doc
section was written). Works fine for me.
Which version of PostGIS are you using?
Run this command:
select postgis_scripts_build_date(), postgis_raster_lib_build_date();
Make sure both return a value later than 2011-01-01
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Deepak R
aj Awasthi
Sent: Sunday, January 22, 2012 12:13 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ST_MapAlgebraExpr() Function
Hello,
I am a M.Sc. student and currently working with postgreSQL/PostGIS to handle
raster. I have installed PostgreSQl 9.0 and PostGIS 2.0 in windows 7
home premium OS. I had no problem on handling raster so far but now I got
problem while accessing ST_MapAlgebraExpr () function which takes two
rasters as function arguments. I have followed the example provided in the
link below as follows.
First, I create the table as given,
CREATE TABLE fun_shapes(rid serial PRIMARY KEY, fun_name text, rast raster);
Then, the second syntax to insert raster and finally the use of the function
ST_MapAlgebraExpr() as.
SELECT ST_MapAlgebraExpr(
area.rast, bub.rast, 'rast2', '8BUI', 'INTERSECTION',
'rast2', 'rast1') As interrast,
ST_MapAlgebraExpr(
area.rast, bub.rast, 'rast2', '8BUI', 'UNION',
'rast2', 'rast1') As unionrast
FROM
(SELECT rast FROM fun_shapes WHERE
fun_name = 'area') As area
CROSS JOIN (SELECT rast
fun_name = 'rand bubbles') As bub
http://postgis.refractions.net/documentation/manual-svn/RT_ST_MapAlgebraExpr
2.html
But I got error on using this syntax as:
ERROR: function st_mapalgebraexpr(raster, raster, unknown, unknown,
unknown, unknown, unknown) does not exist
LINE 58: SELECT ST_MapAlgebraExpr()
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
Although I am new to this database, I think that there is problem with
PostGIS 2.0 to support the function. If this the case which version I have
to install to use this function. Can anyone provide me solution for it.
Thanks
With Best Regards,
Deepak
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120122/38d7e294/attachment.html>
