[postgis-users] migration/upgrade advice
Paragon Corporation
lr at pcorp.us
Thu Jan 26 05:51:51 PST 2012
Oops. My bad. I had a typo on the page. I'll fix. That should have read
January 7, 2012.
If you are using that one, then you should be good to go since I haven't
released a new version yet. Just use the 9.1 binaries on that page and
restore your backup and you should be good to go.
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of John
Callahan
Sent: Wednesday, January 25, 2012 11:50 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] migration/upgrade advice
Thanks Regina. The version I'm running was downloaded last August from
http://www.postgis.org/download/windows/experimental.php, which mentions Jan
7 on that page. "SELECT PostGIS_Full_Version();" returns
"POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.7.6" USE_STATS"
Where is the best location to get the latest postgis? checkout via SVN?
I will give the hard upgrade method a try.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Wed, Jan 25, 2012 at 5:40 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I unfortunately have to move my Postgres/PostGIS database to a new
Windows server. My current (source) db is Postgres 9.0.2 with PostGIS
2.0.0SVN (I believe from Jan 2011.)
January 2011 is a bit old or do you mean 2012?
> The new (destination) db will likely be Postgres 9.1.2. It seems like I
can use pg_dump to go from 9.0.2 to 9.1.2, as long as I use the 9.1 version
of pg_dump. Is that true?
Correct -- I do it alll tthe time.
> For PostGIS 2.0, I plan to install the same version on both the source
and destination db. I'll do this before importing from pg_dump. I can then
update PostGIS on the new db after the migration is complete. Does that
make sense? or should I install a newer version of PostGIS immediately?
Depends how old your version is -- if its really 2011, I'm not sure our
upgrade script can handle that far back cleanly. You can try.
I think your safest bet though is to:
1) Install the newest version of binaries on PostgreSQL 9.1
2) Create a new db with the latest PostGIS 2.0 experimental builds
3) Use hard upgrade process.
http://www.postgis.org/documentation/manual-svn/postgis_installation.html#ha
rd_upgrade (Note: The windows upgrade link for windows specific
instructions) ( http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade )
If we are talking January 2012 -- then
1 ) Install new binaries
2) Restore your backup -- some things might fail to restore, that's okay
3) Rung the postgis_upgrade_20_minor and
rtpostgis_upgrade_20_minor.sql
in the share/contrib folder of the experimental zip folder.
Note: Some changes that require a dump restore have happened since we
distributed the last experimental -- but those changes don't effect raster
functionality
and I plan to release a new build soon once I get my make check working
again.
Hope that helps,
Regina
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120126/1ec5ee56/attachment.html>
