[postgis-users] How to match lines between two similar graphs?
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Jan 26 09:05:29 PST 2012
On 26 January 2012 17:16, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> On 1/26/2012 10:47 AM, Nicolas Ribot wrote:
>>> Hi All,
>>> I have an interesting problem I am trying to solve and would love some
>>> feedback on how to best go about it.
>>> I have road data from two different vendor data sets. But this could also
>>> be
>>> one road network and a GPS track, so I think this is a pretty common use
>>> case.
>>> Assumptions:
>>> o the networks are similar, ie: they have similar roadway coverage
>>> o the two sets might be slightly misaligned, ie: shifted by some amount
>>> o the segments in the two data sets do not have to be broken into
>>> equivalent
>>> segments, ie: one segment in A might be represented my multiple segments
>>> in
>>> B
>>> o segments are not aligned end point wise, ie: a segment in A might go
>>> from
>>> mid-point one segment in B to the midpoint of a connected segment in B
>>> o in many cases I will be working with a set of lines in one set that I
>>> need
>>> to match to the other to select a matching set of lines.
>>> So strategies for matching these:
>>> 1. take a segment from A and buffer it, then intersect the data in B and
>>> select the longest intersected object. I can probably throw out any
>>> pieces
>>> smaller than the buffer distance.
>>> 2. Do the same but buffer and union the set of lines into a single
>>> multipolygon, and intersect that with the other set.
>>> 3. ??? Other ideas?
>>> Thoughts on performance?
>>> Typically I will have a small set (1-20) of segments to compare against a
>>> larger (100K-2M) set. Obvious a spatial index will will be used. But I'm
>>> wondering what is the fast way to do this matching computationally. I
>>> think
>>> I will want to be able to compare 1-200 sets like this every 5 mins as
>>> data
>>> comes in from a feed, while supporting other queries.
>> With this small input set, maybe st_hausdorffDistance() could be
>> useful to select good candidates in the larger set.
> Hi Nicolas,
> Thank you for your insights and suggestions. I have not used
> st_hausdorffDistance() and just read up on it. I agree this might be a good
> option for initial segment selection.
Stephen,
another thought:
Are your input segments connected and forming a longer linestring you
want to "rebuild" against big dataset, or are they independent objects
If the latter, distance search and segment orientation could give good
results, assuming the big dataset segments orientations are
pre-computed:
If the segments are close to each other (in fact, it should be "if all
their vertices are close enough") and the segments orientations are in
a close range, then chances are good you found the right target
segment.
Nicolas
