[postgis-users] Make Check fails
Andreas Forø Tollefsen
andreasft at gmail.com
Tue Jan 31 06:51:37 PST 2012
Hi Mathieu,
Thanks. I was thinking the same. I downloaded the latest from trunk.
./autogen.sh
./configure --with-raster --with-gui
Also tried --with-geosconfig and --with-gdalconfig manually with the same
problem.
Could it be worth a try to delete the postgis-2.0.so file and reinstall
postgis?
Andreas
2012/1/31 Mathieu Basille <basille at ase-research.org>
> It seems indeed to be related to your previous GEOS install. What command
> did you use to compile PostGIS? Is it possible that the path to geos-config
> is still linking to the previous install? You can override it by:
> '--with-geosconfig=/usr/bin/**geos-config' (or the one related to your
> current install of GEOS) in the ./configure.
> Hope it helps. If not, please provide more details (OS, previous commands,
> etc.).
> Mathieu.
> Le 31/01/2012 09:33, Andreas Forø Tollefsen a écrit :
>> Hi,
>> I have installed GEOS 3.3.2 and GDAL 1.9.
>> I previously had a GEOS SVN 3.4 installed, but no longer.
>> Still i get this error when running make check.
>> Any idea?
>> /home/andreas/Downloads/**postgis-2.0.0alpha3SVN/**
>> liblwgeom/cunit/.libs/lt-cu_**testr:
>> error while loading shared libraries: libgeos-3.4.0dev.so
>> <http://libgeos-3.4.0dev.so>: cannot open shared object file: No such
>> file
>> or directory
>> make[2]: *** [check] Error 127
>> make[2]: Leaving directory
>> `/home/andreas/Downloads/**postgis-2.0.0alpha3SVN/**liblwgeom/cunit'
>> make[1]: *** [check] Error 2
>> make[1]: Leaving directory
>> `/home/andreas/Downloads/**postgis-2.0.0alpha3SVN/**liblwgeom'
>> make: *** [check] Error 1
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/**basille <http://ase-research.org/basille>
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/08f21420/attachment.html>
