[postgis-users] Make Check fails
Andreas Forø Tollefsen
andreasft at gmail.com
Tue Jan 31 10:30:20 PST 2012
Great. Thank you for your explanation.
Really appreciate your help!
Andreas
2012/1/31 Mathieu Basille <basille at ase-research.org>
> Le 31/01/2012 10:45, Andreas Forø Tollefsen a écrit :
> Thank you Mathieu!
>> That did it. Could you explain what the commands excactly do, so i know
>> next time?
> From the man page of ldconfig:
> "ldconfig creates, updates, and removes the necessary links and cache
> (for use by the run-time linker, ld.so) to the most recent shared
> libraries found in the directories specified on the command line, in the
> file /etc/ld.so.conf, and in the trusted directories (/usr/lib and /lib)."
> As far as I can tell, it is required to declare where the shared libraries
> (.so) are. And it seems that some systems (at least Debian for what I can
> tell) do not use /usr/local/lib, but just /usr/lib and /lib.
> The command:
> echo '/usr/local/lib' >> /etc/ld.so.conf
> just add '/usr/local/lib' at the end of the file /etc/ld.so.conf, so that
> the system can use /usr/local/lib as a path for the shared libraries. It is
> then re-processed by the call of ldconfig.
> Mathieu.
> Best,
>> Andreas
>> <mailto:basille at ase-research.**org <basille at ase-research.org>>>
>> Arf, I was just too late :)
>> I remember a similar problem with GDAL (also compiled manually), for
>> which the lib .so could not be found. You can first check the paths:
>> /sbin/ldconfig -p | grep geos
>> I have something like that:
>> libgeos_c.so.1 (libc6) => /usr/local/lib/libgeos_c.so.1
>> libgeos_c.so (libc6) => /usr/local/lib/libgeos_c.so
>> libgeos-3.4.0dev.so <http://libgeos-3.4.0dev.so> (libc6) =>
>> /usr/local/lib/libgeos-3.4.__**0dev.so <http://libgeos-3.4.0dev.so>
>> If you don't have this, you can try (use sudo if needed):
>> ldconfig
>> And check again. This should be enough for PostGIS to compile (at least
>> it worked for me).
>> Hope this helps,
>> Mathieu.
>> Le 31/01/2012 10:16, Andreas Forø Tollefsen a écrit :
>> And the file exists:
>> andreas at andreas-priogrid:~/__**Downloads/postgis-2.0.__**0alpha3SVN$
>> locate
>> /home/andreas/Downloads/geos-_**_svn/src/.libs/libgeos-3.4.__**
>> 0dev.so
>> 2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com
>> <mailto:andreasft at gmail.com>
>> <mailto:andreasft at gmail.com <mailto:andreasft at gmail.com>>>
>> <mailto:basille at ase-research._**_org <mailto:basille at ase-research.
>> **org <basille at ase-research.org>>>>
>> Le 31/01/2012 09:51, Andreas Forø Tollefsen a écrit :
>> Hi Mathieu,
>> Thanks. I was thinking the same. I downloaded the
>> latest from
>> trunk.
>> ./autogen.sh
>> ./configure --with-raster --with-gui
>> Also tried --with-geosconfig and --with-gdalconfig
>> manually
>> with the same
>> problem.
>> Could it be worth a try to delete the postgis-2.0.so
>> <http://postgis-2.0.so>
>> <http://postgis-2.0.so> file and reinstall postgis?
>> I don't think it is related to postgis-2.0.so
>> <http://postgis-2.0.so>, but really to the mess with GEOS
>> installs.
>> Try to make sure that you're using the correct
>> geos-config. If
>> you're using a Linux OS, you can try:
>> sudo updatedb
>> locate geos-config
>> See how many do you have. Mine (compiled by myself) is in
>> '/usr/local/bin/geos-config'. You can check if it is the correct
>> one with, e.g. less:
>> less /usr/local/bin/geos-config
>> It shows me somewhere that this is the 3.4.0dev version:
>> --version)
>> echo 3.4.0dev
>> Then I can use:
>> --with-geosconfig=/usr/local/_**___bin/geos-config
>> Now you have to adjust it for your needs. How did you
>> install GEOS
>> 3.3.2? Did you use a package manager, or compile it
>> manually? Only
>> this will tell you which geos-config to use...
>> Mathieu.
>> Hi Mathieu,
>> I have compiled my geos myself using ./autogen.sh, ./configure,
>> make,
>> make install.
>> Then i set the path to the geos-config manually when
>> configuring postgis:
>> ./configure --with-geosconfig=/usr/local/_**_bin/geos-config
>> --with raster
>> I also tried by reinstalling the latest geos3.4.dev from trunk.
>> However. I get the same error:
>> ---- Making check in liblwgeom
>> make[1]: Entering directory
>> `/home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**
>> liblwgeom'
>> make -C cunit check
>> make[2]: Entering directory
>> liblwgeom/cunit'
>> /bin/bash ../../libtool --mode=link gcc -g -O2 -Wall
>> -Wmissing-prototypes -I/usr/local/include
>> -DPOSTGIS_GEOS_VERSION=34 -o
>> cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
>> cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o
>> cu_split.o
>> cu_surface.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o
>> cu_out_gml.o
>> cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_x3d.o
>> cu_in_wkb.o
>> cu_in_wkt.o cu_tester.o ../liblwgeom.la <http://liblwgeom.la>
>> <http://liblwgeom.la> -lcunit
>> libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes
>> -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -o
>> .libs/cu_tester
>> cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o cu_geodetic.o
>> cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
>> cu_surface.o
>> cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
>> cu_out_kml.o
>> cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o
>> cu_in_wkt.o
>> cu_tester.o ../.libs/liblwgeom.so /usr/lib/libcunit.so
>> #gcc -o cu_tester cu_algorithm.o cu_print.o cu_misc.o
>> cu_ptarray.o
>> cu_split.o
>> cu_out_gml.o
>> cu_in_wkb.o
>> cu_in_wkt.o cu_tester.o ../.libs/liblwgeom.a -lm -lcunit
>> -L/usr/local/lib -lgeos_c
>> liblwgeom/cunit/.libs/lt-cu___**tester:
>> error while loading shared libraries: libgeos-3.4.0dev.so
>> <http://libgeos-3.4.0dev.so>: cannot open shared object file: No
>> such
>> file or directory
>> make[2]: *** [check] Error 127
>> make[2]: Leaving directory
>> liblwgeom/cunit'
>> make[1]: *** [check] Error 2
>> make[1]: Leaving directory
>> liblwgeom'
>> make: *** [check] Error 1
>> Andreas
>> <mailto:basille at ase-research. <mailto:basille at ase-research.>**
>> ____org
>> **org <basille at ase-research.org>>>>>
>> It seems indeed to be related to your previous GEOS
>> install. What
>> command did you use to compile PostGIS? Is it
>> possible that
>> the path to
>> geos-config is still linking to the previous
>> install? You
>> can override
>> it by:
>> '--with-geosconfig=/usr/bin/__**____geos-config' (or the
>> one related
>> to your current install of GEOS) in the
>> ./configure.
>> Hope it helps. If not, please provide more details
>> (OS,
>> previous
>> commands, etc.).
>> Mathieu.
>> Le 31/01/2012 09:33, Andreas Forø Tollefsen a
>> écrit :
>> Hi,
>> I have installed GEOS 3.3.2 and GDAL 1.9.
>> I previously had a GEOS SVN 3.4 installed, but
>> no longer.
>> Still i get this error when running make check.
>> Any idea?
>> /home/andreas/Downloads/______**postgis-2.0.0alpha3SVN/______**
>> liblwgeom/cunit/.libs/lt-cu___**____testr:
>> such file
>> or directory
>> `/home/andreas/Downloads/_____**_postgis-2.0.0alpha3SVN/______**
>> liblwgeom/cunit'
>> liblwgeom'
>> ______________________________**_______________________
>> postgis-users mailing list
>> postgis-users at postgis.__refrac**____tions.net<http://refrac____tions.net>
>> <http://refrac__tions.net>
>> <http://refractions.net>
>> <mailto:postgis-users at postgis.
>> <mailto:postgis-users at postgis.**>____refractions.net
>> <mailto:postgis-users at postgis.**__refractions.net
>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.___**___net/mailman/listinfo/**
>> postgis-______users
>> <http://postgis.refractions.__**__net/mailman/listinfo/**
>> postgis-____users
>> <http://postgis.refractions.__**net/mailman/listinfo/postgis-_**
>> _users
>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> ~$ whoami
>> Mathieu Basille, Post-Doc
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de
>> Conservation
>> de la Faune
>> + Centre d'Étude de la Forêt
>> Département de Biologie
>> Université Laval, Québec
>> ~$ info
>> http://ase-research.org/______**basille<http://ase-research.org/______basille>
>> <http://ase-research.org/____**basille<http://ase-research.org/____basille>
>> <http://ase-research.org/__**basille<http://ase-research.org/__basille>
>> <http://ase-research.org/__**basille<http://ase-research.org/__basille><
>> http://ase-research.org/**basille <http://ase-research.org/basille>>>>
>> ~$ fortune
>> ``If you can't win by reason, go for volume.''
>> Calvin, by Bill Watterson.
>> postgis-______users
>> postgis-____users
>> _users
>> postgis-users at postgis.__refrac**__tions.net<http://refrac__tions.net>
>> http://postgis.refractions.___**_net/mailman/listinfo/postgis-**
>> ____users
>> _users
>> ~$ whoami
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de Conservation
>> de la Faune
>> ~$ info
>> ~$ fortune
>> ____users
>> _users
>> postgis-users at postgis.__refrac**tions.net <http://refractions.net>
>> _users
>> ~$ whoami
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
>> ~$ info
>> ~$ fortune
>> http://postgis.refractions.__**net/mailman/listinfo/postgis-_**_users
> ~$ whoami
> ~$ locate
> ~$ info
> ~$ fortune
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/b533ee93/attachment.html>
