[postgis-users] Installation of PL/R: Updata
Volkmar Herbst
volkmar.herbst at gmx.de
Tue Jan 31 23:05:02 PST 2012
Thanks for the info- good to know. Also for me the PostGis in action book
was the start- very well written and of great practical use.
Good luck with your project.
Volkmar
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von Darrel
Maddy
Gesendet: Dienstag, 31. Januar 2012 21:30
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] Installation of PL/R: Updata
Dear Volkmar,
I contacted the author (Joe Conway) of the PL/R package and he confirmed
that the dll had not yet been compiled for PG9.1.2 - clearly being a decent
chap he quickly produced a dll for me which I am glad to report works as
intended (I think he will do a little more testing before releasing it into
the wild) - sometime the open source community make me glad to be alive! J.
Thumbs up also for Regina/Leo and the PostGIS in action book, Ch10 had me
using PL/R in no time - so now I only have to learn postgresql, postgis and
R - sounds like some fun days ahead. No doubt I'll be back.
Darrel
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Volkmar
Herbst
Sent: 30 January 2012 07:18
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] Installation of PL/R
HI,
I did install R several times and run also often into this issue. Try the
32bit one and set the path C:\Program Files\R\R-2.13.1\bin\i386 in your
environment. Create new variable R_HOME value->C:\Program Files\R\R-2.13.1
Make sure that plr.dll is in C:\Program Files (x86)\PostgreSQL\9.0\lib.
Restart postgres after that. If you receive errors check if you did not
install it already by using plr_environ() in postgres. These are the few
things I can think of. May be you have already tried them all..
Volkmar
Von: <mailto:postgis-users-bounces at postgis.refractions.net>
<mailto:[mailto:postgis-users-bounces at postgis.refractions.net]>
Maddy
Gesendet: Samstag, 28. Januar 2012 18:45
An: <mailto:postgis-users at postgis.refractions.net>
Betreff: [postgis-users] Installation of PL/R
Apologies if this is not the right mail list for this but my confusion
arises because of my 32 bit PostGIS install!
I have postgis2SVN sitting on top of postgresql 9.1 (32 bit) on a 64 bit
version of windows (working fine). I installed R-2.14.1 and tried to follow
the instructions given here
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tu
t01
Now I tried both the 32bit and 64bit dll from http://www.joeconway.com/plr/
I ran the sql script supplied but get ERROR: could not load library
"C:/Program Files (x86)/PostgreSQL/9.1/lib/plr.dll": The specified procedure
could not be found.
Needless to say plr.dll is in that location (I have tried both versions).
Any suggestions would be welcome (and apologies if this is a dumb question).
Thanks
Darrel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120201/83088d07/attachment.html>
