[postgis-users] Compilation Issue of Postgis-2.0.0 on MinGW
Paragon Corporation lr at pcorp.us
Mon Jul 2 12:40:52 PDT 2012
Which version of GEOS are you using?  Might be your path setting for geos is
wrong.  I don't ahve issue compiling trunk under mingw 32 or 64-bit and am
using geos 3.4.0 dev
Thanks,
Regina
http://www.postgis.us
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Owais
Khan
Sent: Monday, July 02, 2012 10:50 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Compilation Issue of Postgis-2.0.0 on MinGW
Hello All,
I was reading following thread but it ends un completed.
http://old.nabble.com/PostGIS-compile-problem-td33409929.html
I will be thankful if someone can point towards resolution of this.
Thanks & Regards,
Owais.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120702/3bdbc3e8/attachment.html>
