[postgis-users] Compilation Issue of Postgis-2.0.0 on MinGW
Paragon Corporation
lr at pcorp.us
Mon Jul 2 12:45:50 PDT 2012
Take a look at these instructions if you haven't already:
http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile
We are working on building a self-contained ming environment for both 64-bit
and 32-bit. We have the 64-bit one dones. We are moving the 32-bit to use
the mingw64-win32 environment that we can make available as a tarball. Hope
to have that ready in the next couple of weeks. The newer 32-bit regular
mingw is finicky because you can't do everything with the newer (thus you
see a Visual C++ hybrid instructions) and other older only has GCC 3.4.5
9which is what we currently use to build the 32-bit chain) thus the need for
us to switch.
Hope this helps,
Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Owais
Khan
Sent: Monday, July 02, 2012 10:50 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Compilation Issue of Postgis-2.0.0 on MinGW
Hello All,
I was reading following thread but it ends un completed.
http://old.nabble.com/PostGIS-compile-problem-td33409929.html
I will be thankful if someone can point towards resolution of this.
Thanks & Regards,
Owais.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120702/4ba83e3b/attachment.html>
