[postgis-users] Length of a line above polygon
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Jul 3 04:41:15 PDT 2012
You can use something like
SELECT areas.id, SUM( ST_Length( lines.geometry) ) FROM lines,areas
WHERE ST_Intersects(lines.geometry,areas.geometry) GROUP BY areas.id ;
Greetings,
Denis
On 07/03/2012 01:36 PM, Matej Mailing wrote:
> Hi all,
> We have a layer that contains polygons and another that contains lines
> that lie on them. Parts of the lines are laying "inside" the polygons
> and I would like to get a sum of all the lengths of lines that lie on
> the polygons. What is the easiest way to achieve this?
> TIA,
> Matej
> postgis-users mailing list
