[postgis-users] possible bug: function st_asgeojson(geometry) is not unique
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed Jul 11 00:53:30 PDT 2012
Thanks Regina and Strk for the enlightment on this.
I will definately stay with the old-fashioned way then, since I use
release candidates quite often and prefer to be bitten as least as possible.
A final question:
Provided that I had a fresh postgis extension on my database but
contaminated it by using a restore from data that included postgis stuff,
what would be the best way to clean up my current database?
Best regards,
Tom
On 11-7-2012 2:53, Paragon Corporation wrote:
> The only issue I see with CREATE EXTENSION at this point is that if you want
> to use the subversion releases
> because they don't have extension version points (which CREATE EXTENSION
> requires freeze points)
> , it's not upgradeable. I have a work around for that issue which I'm
> experimenting with. That only affects people who want to live on the edge
> like strk.
> If you always go with released versions, it works just dandy from my
> experience. So in a nut-shell its fine for production use, just hard to use
> for interim synching with repository version.
> strk is just against it because he got bitten once early on and he had a
> mixed bag of stuff anyway.
> As far as upgrading from say 1.5. If you did an unclean upgrade -- brought
> over junk and installed on top of a clean postgis 2.0,
> YOU NEED to run the postgis_upgrade_minor script or you'll get ambiguous
> function calls as you've experienced.
> Hope that helps,
> Regina
> http://www.postgis.us
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of Tom van Tilburg
>> Sent: Tuesday, July 10, 2012 6:33 AM
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] possible bug: function
>> On 10-7-2012 12:16, Sandro Santilli wrote:
>>>> Also I see no double functions in public.functions nor are there
>>>> functions in any other place installed in the database.
>>> select * from pg_proc where proname = 'st_asgeojson'; (I
>> have 5 rows)
>> Seems I spoke too soon.. I just created a brand new empty
>> database and added postgis by extension.
>> It worked correctly.
>> The previous database was also new but I imported a lot of
>> data that came from an earlier postgis database. Seems I
>> accidently copied some postgis functions somewhere because
>> "select * from pg_proc where proname = 'st_asgeojson';"
>> returned 11 rows (!).
>> Thanks for your input!
>> P.S. Do I understand correctly that CREATE EXTENSION is not a
>> preferred method for postgis?
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
