[postgis-users] Are views slow ing down my wms?
Francois Hugues hugues.francois at irstea.fr
Thu Jul 12 04:47:02 PDT 2012
Hello,
It will take sometimes to retrieve the set of data from the view relative to its complexity. Is the request which define the view simple or does it have complex and / or spatial operator ? Does your spatial data have a lot of points ? Did you make indexes on the columns used by your views ?
Hugues.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Robert Buckley
Envoyé : jeudi 12 juillet 2012 07:30
À : Post GIS Users Discussion
Objet : [postgis-users] Are views slow ing down my wms?
I have created a database structure which has 3 main postgis tables (1 for lines,polygones, and points) which each contain between 5-10,000 features. These tables then feed views which split the geometries into understandable groups which are then served through geoserver in Tomcat6, linux-Ubuntu 10.04.
I have noticed that the performance of the wms is getting considerably worse. Is this to do with the views or simply the amount of data being served?
Should I in hindsight have split the table into separate tables instead of creating views?
thanks for any help,
Robert
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120712/e104f600/attachment.html>
