[postgis-users] Need help constructing a query
Tom van Tilburg
tom.van.tilburg at gmail.com
Thu Jul 19 23:38:47 PDT 2012
Hi Pedro,
You might try to create lines from the boat tracks (see examples in
manual for ST_MakeLine) and circles (st_buffer) from the proximity
areas around the buoy.
Now do a ST_Intersection(boatline, bouycircle). The result should be a
set of lines within the bouycircle. Every line stands for one pass along
the bouy.
I think ST_Intersection might result in a geometry collection of lines
and points so you would have to make a dump of the result with ST_Dump
and then select only the lines.
Cheers,
Tom
On 19-7-2012 20:03, Pedro Doria Meunier wrote:
> Hi,
> Need help/pointers on how to best construct the following:
> 1 known point in a table. (call it buoy)
> another table containing the history (with a geom column) of where a
> particular object (a boat) has been in time/space
> What I need to construct is a query that gives me the count of how
> many times that boat has gone past that buoy.
> (there *will* be more than 1 rows giving proximity of the object to
> the buoy -- need to get rid of those ;) -- since the boat is slow
> moving (2-10 knots))
> Btw, both tables' geoms srid=4326.
> Any help highly appreciated ;)
> TIA,
> Pedro Doria Meunier
> Telf. +351 291 933 006
> GSM +351 917 999 236
> Skype: pdoriam
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120720/f4a6d32d/attachment.html>
