[postgis-users] Signal 11: Segmentation fault
Rebecca Clarke
r.clarke83 at gmail.com
Fri Jul 20 00:49:43 PDT 2012
But that doesn't explain why it's just started happening. Can you give me a
link that tells me what the bug is.
Cheers
On Thu, Jul 19, 2012 at 6:22 PM, Sandro Santilli <strk at keybit.net> wrote:
> Sounds like a bad bug recently discovered and already fixed in the
> repository. You'll have to upgrade to 1.5.5, but it isn't out yet.
> If you filed a bug it may put some more pressure to the release manager :)
> --strk;
> On Thu, Jul 19, 2012 at 05:37:12PM +0100, Rebecca Clarke wrote:
> > Hi there
> > I'm running Postgresql 8.4 with postgis 1.5.
> > I have a table that contains roughly 2000 records.
> > The geometry in the table is a polygon.
> > I can run the following query with no problems
> > select the_geom from mytable;
> > However when I run something like this:
> > select st_centroid(the_geom) from mytable;
> > or
> > select st_isvalid(the_geom) from mytable;
> > I get the following error everytime:
> > 2012-07-19 17:23:47 BST LOG: server process (PID 19445) was terminated
> by
> > signal 11: Segmentation fault
> > 2012-07-19 17:23:47 BST LOG: terminating any other active server
> processes
> > 2012-07-19 17:23:47 BST LOG: all server processes terminated;
> > reinitializing
> > 2012-07-19 17:23:47 BST LOG: database system was interrupted; last known
> > up at 2012-07-19 17:23:33 BST
> > 2012-07-19 17:23:47 BST LOG: database system was not properly shut down;
> > automatic recovery in progress
> > 2012-07-19 17:23:47 BST LOG: record with zero length at 1406/B6388B94
> > 2012-07-19 17:23:47 BST LOG: redo is not required
> > 2012-07-19 17:23:47 BST LOG: autovacuum launcher started
> > 2012-07-19 17:23:47 BST LOG: database system is ready to accept
> connections
> > If I limit the query to 100 records it works.
> > In the same table I have another geometry that is a point. When I run the
> > st_isvalid against that, it does not error.
> > What is strange is this has only just started happening. I thought it
> was a
> > hardware issue, so I completely dumped the database and recreated it on
> > another server but the issue persisted. I'm not sure what I have done
> wrong.
> > The data originates from an mdb. The geom's were stored as OLE Objects.
> > When I imported them into postgres they were bytea. I converted them with
> > st_geomfromewkb(the_geom).
> > Any help or directions on where I can go to figure out how to solve this
> > issue would be great.
> > Thanks
> > Rebecca
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120720/0df7e6a1/attachment.html>
