[postgis-users] postgis-1.5.4 deprecated function in postgresql-9.1.4?
Jason Mahony
jason at verticalresponse.com
Mon Jul 23 10:33:37 PDT 2012
Hi there,
I'm trying to upgrade a postgres-8.4 installation using pg_dumpall from a new 9.1.4 install with a subsequent load.
[root at pgsql-9.1.4 ~]# time pg_dumpall -Upostgres -c -h pgsql-8.4.domainname.com | psql -Upostgres
It seems to be working fine with the exception of a few Postgis errors thrown at the end of the postgres load.
ERROR: could not find function "lwhistogram2d_in" in file "/usr/lib64/pgsql/liblwgeom.so"
ERROR: function public.st_histogram2d_in(cstring) does not exist
ERROR: could not find function "lwhistogram2d_out" in file "/usr/lib64/pgsql/liblwgeom.so"
ERROR: function public.st_histogram2d_out(histogram2d) does not exist
ERROR: function st_histogram2d_in(cstring) does not exist
ERROR: could not find function "build_lwhistogram2d" in file "/usr/lib64/pgsql/liblwgeom.so"
ERROR: function public.build_histogram2d(histogram2d, text, text) does not exist
ERROR: PL/pgSQL functions cannot return type histogram2d
I've installed the following postgis RPMs:
[root at vrsdb03 ~]# rpm -qa |grep postgis91
postgis91-1.5.4-1.rhel6.x86_64
postgis91-utils-1.5.4-1.rhel6.x86_64
As well as doing a necessary compile of the postgis source against my postgresql-9.1.4 install.
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/bin/geos-config
GEOS version: 3.3.5
PostgreSQL config: /usr/pgsql-9.1/bin//pg_config
PostgreSQL version: PostgreSQL 9.1.4
PROJ4 version: 47
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.6
PostGIS debug level: 0
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex:
convert:
I also created a softlink between the /usr/pgsql-9.1/lib standard library to the /usr/lib64/pgsql old library used in the 8.4 install. Making this link seemed to alleviate a few other errors that no longer occur.
[root at pgsql-9.1.4 lib64]# pwd
/usr/lib64
[root at pgsql-9.1.4 lib64]# ll pgsql
lrwxrwxrwx 1 root root 19 Jul 21 13:53 pgsql -> /usr/pgsql-9.1/lib/
[root at pgsql-9.1.4 lib64]# ll pgsql/liblwgeom.so pgsql/postgis-1.5.so
lrwxrwxrwx 1 root root 14 Jul 20 08:39 pgsql/liblwgeom.so -> postgis-1.5.so
-rwxr-xr-x 1 root root 1975408 Jul 21 19:52 pgsql/postgis-1.5.so
Thanks,
Jason Mahony
Systems Engineer
Mobile: 415-471-9131
VerticalResponse, Inc
** Save a tree. Don't print me **
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120723/1414a084/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120723/1414a084/attachment.pgp>
