[postgis-users] Extracting points from a line
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed Jul 25 04:30:32 PDT 2012
Hi Rob,
Points in a regular interval have always been a pain to create in
postgis. I hope someone will write a decent linear_reference code for
this some time soon.
Here's a way to do it:
1) make a line out of your points (ST_SetSrid(ST_MakeLine(pointa,
pointb), 27700))
2) add an M value to your line (ST_AddMeasure(geom, start, end))
3) generate_series of intervals
generate_series(0,floor(ST_Length(geom)/25.0)) < please check how to
deal with that last segment smaller than 25 meter!
4) now you know how many points you need in every line you can use
(ST_Line_Interpolate_Point(geom, (N*25)/St_Length(geom))
when N being the numbers you got from generate series in 3).
Make sure not to put dimensional restrictions to your tables since
ST_AddMeasure will want to add that extra M dimension.
Good luck!
Tom
On 25-7-2012 12:50, uk52rob wrote:
> Hi,
> I have two point geometry tables, with which I need to compare a
> single point from the left table to all points in the right table.
> I need to extract X and Y co-ordinates (EPSG: 27700 OSGB36/British
> National Grid) every 25m along a fictitious line between the points in
> order to build a 'profile' of the land from a database containing
> height data.
> Does anyone have any 'best practise' or experience with this sort of
> project?
> Many thanks,
> Rob
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120725/24d8a74a/attachment.html>
