[postgis-users] Signal 11: Segmentation fault
    Rebecca Clarke
    r.clarke83 at gmail.com
    Wed Jul 25 05:02:59 PDT 2012
I have resolved the issue.
It was happening because there was a record with an empty polygon.
When I added this code into the query it worked successfully.
CASE WHEN ST_IsEmpty(st_astext(the_geom)) THEN false ELSE
st_isvalid(the_geom) END
On Fri, Jul 20, 2012 at 6:25 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Actually, this doesn't match our fixed but, which was an index
> node-splitting bug that only triggered when new data was inserted. But
> your crash is happening then you query. The difference between the
> whole table and the limit query points to the problem being a specific
> record. The fact that you could dump the table and restore it and
> *still* get the problem is very surprising. The idea that it could all
> work for a while and then simply start failing is the most confusing
> part of all.
> Can you share
> (a) a dump of your table
> (b) the queries you run
> (c) the exact versions you are running
> (d) your operating system information
> (e) your hardware platform
> If we can replicate the bug, we can probably fix it. You don't have to
> share your info publicly, just email me and/or strk.
> P.
> On Fri, Jul 20, 2012 at 12:49 AM, Rebecca Clarke <r.clarke83 at gmail.com>
> wrote:
> > But that doesn't explain why it's just started happening. Can you give
> me a
> > link that tells me what the bug is.
> > Cheers
> > On Thu, Jul 19, 2012 at 6:22 PM, Sandro Santilli <strk at keybit.net>
> wrote:
> >> Sounds like a bad bug recently discovered and already fixed in the
> >> repository. You'll have to upgrade to 1.5.5, but it isn't out yet.
> >> If you filed a bug it may put some more pressure to the release manager
> >> --strk;
> >> On Thu, Jul 19, 2012 at 05:37:12PM +0100, Rebecca Clarke wrote:
> >> > Hi there
> >> > I'm running Postgresql 8.4 with postgis 1.5.
> >> > I have a table that contains roughly 2000 records.
> >> > The geometry in the table is a polygon.
> >> > I can run the following query with no problems
> >> > select the_geom from mytable;
> >> > However when I run something like this:
> >> > select st_centroid(the_geom) from mytable;
> >> > or
> >> > select st_isvalid(the_geom) from mytable;
> >> > I get the following error everytime:
> >> > 2012-07-19 17:23:47 BST LOG:  server process (PID 19445) was
> terminated
> >> > by
> >> > signal 11: Segmentation fault
> >> > 2012-07-19 17:23:47 BST LOG:  terminating any other active server
> >> > processes
> >> > 2012-07-19 17:23:47 BST LOG:  all server processes terminated;
> >> > reinitializing
> >> > 2012-07-19 17:23:47 BST LOG:  database system was interrupted; last
> >> > known
> >> > up at 2012-07-19 17:23:33 BST
> >> > 2012-07-19 17:23:47 BST LOG:  database system was not properly shut
> >> > down;
> >> > automatic recovery in progress
> >> > 2012-07-19 17:23:47 BST LOG:  record with zero length at 1406/B6388B94
> >> > 2012-07-19 17:23:47 BST LOG:  redo is not required
> >> > 2012-07-19 17:23:47 BST LOG:  autovacuum launcher started
> >> > 2012-07-19 17:23:47 BST LOG:  database system is ready to accept
> >> > connections
> >> > If I limit the query to 100 records it works.
> >> > In the same table I have another geometry that is a point. When I run
> >> > the
> >> > st_isvalid against that, it does not error.
> >> > What is strange is this has only just started happening. I thought it
> >> > was a
> >> > hardware issue, so I completely dumped the database and recreated it
> on
> >> > another server but the issue persisted. I'm not sure what I have done
> >> > wrong.
> >> > The data originates from an mdb. The geom's were stored as OLE
> Objects.
> >> > When I imported them into postgres they were bytea. I converted them
> >> > with
> >> > st_geomfromewkb(the_geom).
> >> > Any help or directions on where I can go to figure out how to solve
> this
> >> > issue would be great.
> >> > Thanks
> >> > Rebecca
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120725/6a9be439/attachment.html>
