[postgis-users] Signal 11: Segmentation fault
Sandro Santilli strk at keybit.net
Wed Jul 25 06:10:53 PDT 2012
On Wed, Jul 25, 2012 at 01:02:59PM +0100, Rebecca Clarke wrote:
> I have resolved the issue.
> It was happening because there was a record with an empty polygon.
> When I added this code into the query it worked successfully.
> CASE WHEN ST_IsEmpty(st_astext(the_geom)) THEN false ELSE
> st_isvalid(the_geom) END
So are you saying that ST_IsValid('POLYGON EMPTY'::geometry) and
ST_Contains('POLYGON EMPTY'::geometry, 'POLYGON EMPTY'::geometry)
both crash for you ?
They work fine for me as of PostGIS 1.5.4
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.1
  |  / 2.1 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
