[postgis-users] ST_AsRaster and gdal_translate
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Wed Jul 25 13:44:13 PDT 2012
Forget to mention:
When you CREATE TABLE rast2export, add a 'rid' column with any number. The GDAL driver is still dependent on that in GDAL 1.9.0 (and BTW the source table was wrong in my last mail):
CREATE TABLE rast2export AS
SELECT 1 rid, ST_Union(rast) rast
FROM rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Pierre Racine
> Sent: Wednesday, July 25, 2012 4:40 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ST_AsRaster and gdal_translate
> If he does that he will not get the right value from his polygon layer...
> The right way to create an exportable raster from a polygon table it to:
> 1) Rasterize and align properly your geometries (adding the gridx and gridy
> parameters to ST_AsRaster and the pixeltype and value to burn the right value):
> CREATE TABLE rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m AS
> SELECT ST_AsRaster(hyd.geom, 1000.0, 1000.0, 0.0, 0.0, '32BUI'::text,
> nameOfTheColumnContainingTheValueToBurn ) AS rast
> FROM hydrology.bdtq_20k_hydro_so_gfsm_aea_subset AS hyd;
> 2) Union the table.
> If your raster is very small you can do:
> SELECT ST_Union(rast) rast
> If your raster is big, ST_Union is too slow. You have to use the method I describe
> in my blog
> http://geospatialelucubrations.blogspot.ca/2012/07/a-slow-yet-1000x-faster-
> alternative-to.html
> 3) Then you can GDAL_translate using mode=1
> Sorry it is so complicated...
> In the future there should just be a ST_UnionToRaster() function, planned in the
> specifications, that rasterize all the geometries to a common raster and then
> export. So just two minimal steps.
> Pierre
> > bounces at postgis.refractions.net] On Behalf Of Bborie Park
> > Sent: Wednesday, July 25, 2012 4:23 PM
> > To: postgis-users at postgis.refractions.net
> > For exporting, instead of using the rasters in
> > "bdtq_20k_hydro_so_gfsm_aea_subset_1000m", you may want to try
> > something
> > like...
> > CREATE TABLE foo AS
> > SELECT 1 AS rid, ST_AsRaster((
> > SELECT
> > ST_Collect(geom)
> > ), 1000.0, 1000.0
> > ) AS rast
> > The above creates one raster using the collection of geometries, which
> > can then be exported with gdal_translate.
> > -bborie
> > On 07/25/2012 12:57 PM, Guillaume Drolet DRF wrote:
> > > Hi,
> > > I have been struggling with this since yesterday and now I think it is
> > > time for me to request some help from the community :
> > > I am trying to convert a geometry table (polygons) to a raster that will
> > > have 1000 m-pixels, and then export that raster to a TIF file using
> > > gdal_translate.
> > > I've tried loads of different queries but nothing seems to work... Here
> > > are examples of some the queries I tried:
> > > SELECT ST_AsRaster(hyd.geom, 1000.0, 1000.0) AS rast
> > > ALTER TABLE rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m ADD
> > COLUMN
> > > rid serial PRIMARY KEY;
> > > CREATE INDEX
> > > ON rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m
> > > USING gist(st_convexhull(rast));
> > > SELECT AddRasterConstraints('rasters'::name,
> > > 'bdtq_20k_hydro_so_gfsm_aea_subset_1000m'::name,
> > > 'rast'::name);
> > > Then at the command line:
> > >>gdal_translate "PG:host=localhost port=5432 dbname=testspdb
> > > user=postgres password=*** schema=rasters
> > > table=bdtq_20k_hydro_so_gfsm_aea_subset_1000m mode=2"
> > > E:\temp\hydro1000m.tif
> > > I get this error:
> > > ERROR 1: Error, the table
> > > rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m contains tiles with
> > > different size, and irregular blocking is not supported yet
> > > GDALOpen failed - 1
> > > Error, the table rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m
> > > contains tiles
> > > with different size, and irregular blocking is not supported yet
> > > My problem seems to be related to the irregular blocking of my raster. I
> > > though I could create a raster with regular block and pixel size but I
> > > didn't figure how to do this yet. I tried to achieve this by creating an
> > > empty raster:
> > > CREATE TABLE rasters.test_rasterize (
> > > rid serial PRIMARY KEY,
> > > rast raster
> > > INSERT INTO rasters.test_rasterize VALUES (
> > > 1,
> > > ST_MakeEmptyRaster(45, 62, 1828552.00, 1422569.00, 1000.0, 1000.0,
> > > 0.0, 0.0, 3175)
> > > -- 45 and 62 are the approximate numbers of 1000 m pixels in x and y
> > > that fit inside the extent of my geometry layer
> > > UPDATE rasters.test_rasterize
> > > SET rast = ST_AsRaster(geom, 1000.0, 1000.0)
> > > FROM hydrology.bdtq_20k_hydro_so_gfsm_aea_subset;
> > > When I call gdal_translate with rasters.test_rasterize, I get this:
> > > Input file size is 2, 4
> > > 0...10...20...30...40...50...60...70...80...90...100 - done.
> > > I'm getting desperate and will greatly appreciate any hints!
> > > If that can help, I'm using PostGIS 2.0.0 r9605 and GDAL 1.9.0
> > > Many thanks,
> > > Guillaume
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Bborie Park
> > Programmer
> > Center for Vectorborne Diseases
> > UC Davis
> > 530-752-8380
> > bkpark at ucdavis.edu
