[postgis-users] ST_AsRaster and gdal_translate
Bborie Park
bkpark at ucdavis.edu
Wed Jul 25 13:45:49 PDT 2012
By the looks of it, there is no burning of values from the polygon
layer, as per the call to ST_AsRaster().
CREATE TABLE rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m AS
SELECT ST_AsRaster(hyd.geom, 1000.0, 1000.0) AS rast
FROM hydrology.bdtq_20k_hydro_so_gfsm_aea_subset AS hyd;
That would just burn 1 or 0 (NODATA).
-bborie
On 07/25/2012 01:40 PM, Pierre Racine wrote:
> If he does that he will not get the right value from his polygon layer...
> The right way to create an exportable raster from a polygon table it to:
> 1) Rasterize and align properly your geometries (adding the gridx and gridy parameters to ST_AsRaster and the pixeltype and value to burn the right value):
> SELECT ST_AsRaster(hyd.geom, 1000.0, 1000.0, 0.0, 0.0, '32BUI'::text, nameOfTheColumnContainingTheValueToBurn ) AS rast
> 2) Union the table.
> If your raster is very small you can do:
> CREATE TABLE rast2export AS
> SELECT ST_Union(rast) rast
> FROM rasters.bdtq_20k_hydro_so_gfsm_aea_subset
> If your raster is big, ST_Union is too slow. You have to use the method I describe in my blog
> http://geospatialelucubrations.blogspot.ca/2012/07/a-slow-yet-1000x-faster-alternative-to.html
> 3) Then you can GDAL_translate using mode=1
> Sorry it is so complicated...
> In the future there should just be a ST_UnionToRaster() function, planned in the specifications, that rasterize all the geometries to a common raster and then export. So just two minimal steps.
> Pierre
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of Bborie Park
>> Sent: Wednesday, July 25, 2012 4:23 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: Re: [postgis-users] ST_AsRaster and gdal_translate
>> For exporting, instead of using the rasters in
>> "bdtq_20k_hydro_so_gfsm_aea_subset_1000m", you may want to try
>> something
>> like...
>> CREATE TABLE foo AS
>> SELECT 1 AS rid, ST_AsRaster((
>> SELECT
>> ST_Collect(geom)
>> ), 1000.0, 1000.0
>> ) AS rast
>> The above creates one raster using the collection of geometries, which
>> can then be exported with gdal_translate.
>> -bborie
>> On 07/25/2012 12:57 PM, Guillaume Drolet DRF wrote:
>>> Hi,
>>> I have been struggling with this since yesterday and now I think it is
>>> time for me to request some help from the community :
>>> I am trying to convert a geometry table (polygons) to a raster that will
>>> have 1000 m-pixels, and then export that raster to a TIF file using
>>> gdal_translate.
>>> I've tried loads of different queries but nothing seems to work... Here
>>> are examples of some the queries I tried:
>>> ALTER TABLE rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m ADD
>> COLUMN
>>> rid serial PRIMARY KEY;
>>> CREATE INDEX
>>> ON rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m
>>> USING gist(st_convexhull(rast));
>>> SELECT AddRasterConstraints('rasters'::name,
>>> 'bdtq_20k_hydro_so_gfsm_aea_subset_1000m'::name,
>>> 'rast'::name);
>>> Then at the command line:
>>>> gdal_translate "PG:host=localhost port=5432 dbname=testspdb
>>> user=postgres password=*** schema=rasters
>>> table=bdtq_20k_hydro_so_gfsm_aea_subset_1000m mode=2"
>>> E:\temp\hydro1000m.tif
>>> I get this error:
>>> ERROR 1: Error, the table
>>> rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m contains tiles with
>>> different size, and irregular blocking is not supported yet
>>> GDALOpen failed - 1
>>> Error, the table rasters.bdtq_20k_hydro_so_gfsm_aea_subset_1000m
>>> contains tiles
>>> with different size, and irregular blocking is not supported yet
>>> My problem seems to be related to the irregular blocking of my raster. I
>>> though I could create a raster with regular block and pixel size but I
>>> didn't figure how to do this yet. I tried to achieve this by creating an
>>> empty raster:
>>> CREATE TABLE rasters.test_rasterize (
>>> rid serial PRIMARY KEY,
>>> rast raster
>>> INSERT INTO rasters.test_rasterize VALUES (
>>> 1,
>>> ST_MakeEmptyRaster(45, 62, 1828552.00, 1422569.00, 1000.0, 1000.0,
>>> 0.0, 0.0, 3175)
>>> -- 45 and 62 are the approximate numbers of 1000 m pixels in x and y
>>> that fit inside the extent of my geometry layer
>>> UPDATE rasters.test_rasterize
>>> SET rast = ST_AsRaster(geom, 1000.0, 1000.0)
>>> FROM hydrology.bdtq_20k_hydro_so_gfsm_aea_subset;
>>> When I call gdal_translate with rasters.test_rasterize, I get this:
>>> Input file size is 2, 4
>>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>>> I'm getting desperate and will greatly appreciate any hints!
>>> If that can help, I'm using PostGIS 2.0.0 r9605 and GDAL 1.9.0
>>> Many thanks,
>>> Guillaume
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
