[postgis-users] ST_Clip
Paolo Cavallini
cavallini at faunalia.it
Thu Jul 26 07:52:46 PDT 2012
Il 26/07/2012 16:33, Pierre Racine ha scritto:
> So the big square, in your image, is a whole 64x64 tile?
not; I tried with a smaller buffer, I obtained a smaller square.
> I gave a try to the same kind of query here and everything is fine. Are you sure the circle is the same geometry used to clip?
it should be: I relaunched the same command, just removing the ST_Clip
> What about SELECT ST_PostGIS_Full_Version()
SELECT ST_PostGIS_Full_Version();
ERROR: function st_postgis_full_version() does not exist
SELECT PostGIS_Full_Version();
POSTGIS="2.0.1 r9979" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.8.0" RASTER
Thanks a lot.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
