[postgis-users] ST_Clip
Stefano Iacovella
stefano.iacovella at gmail.com
Thu Jul 26 08:23:53 PDT 2012
Paolo
I am not sure if this is related to your issue but you may want to
upgrade to GEOS 3.3.5 as there was an issue in 3.3.3 and 3.3.4
http://trac.osgeo.org/geos/ticket/558
Regards
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/7/26 Paolo Cavallini <cavallini at faunalia.it>:
> Il 26/07/2012 16:33, Pierre Racine ha scritto:
>> So the big square, in your image, is a whole 64x64 tile?
> not; I tried with a smaller buffer, I obtained a smaller square.
>> I gave a try to the same kind of query here and everything is fine. Are you sure the circle is the same geometry used to clip?
> it should be: I relaunched the same command, just removing the ST_Clip
>> What about SELECT ST_PostGIS_Full_Version()
> SELECT ST_PostGIS_Full_Version();
> ERROR: function st_postgis_full_version() does not exist
> SELECT PostGIS_Full_Version();
> POSTGIS="2.0.1 r9979" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.8.0" RASTER
> Thanks a lot.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> postgis-users mailing list
