[postgis-users] distance from centroid to the points that form the outer boundary of the polygon
Tom van Tilburg tom.van.tilburg at gmail.com
Mon Jul 30 13:05:23 PDT 2012
Hi Yamini,
Are you sure that multipolygons is what you want to work with? Since a
multipolygon can consist of multiple polygons (obviously) who share a
common centroid that can be way outside your actual polygons.
That said, I would make use of ST_Dumppoints to do that.
Something like:
WITH pointsdump AS
     SELECT gid, ST_Centroid(geom) AS centre, (ST_Dumppoints(geom)).geom
AS point FROM polygontable
SELECT gid, ST_Distance(centre, point) AS distance FROM pointsdump
Now for every point in a geometry with a known gid you will see the
distance to it's centroid.
You can do statistics on these numbers with something like:
     SELECT gid, avg(distance) avg, max(distance) max, etc... FROM
results GROUP BY gid
Cheers,
  Tom
On 30-7-2012 15:04, Yamini Singh wrote:
> Hi All,
> I am looking for suggestions for the following problem I have at hand.
> 1.I have a table that contain multipolygons
> 2.I want to calculate the maximum distance of points that form the
> polygon  from the centroid of the polygon. For example of the polygon
> is formed of 50 points then I want to have distance of all the 50
> points from the centroid of the polygon.
> I am not sure if someone has done this before. But I am finding it
> difficult to implement it. Any help in this regards is welcome...
> Best,
> YJS
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120730/ca1e4814/attachment.html>
