[postgis-users] Help with PL/PGSQL!
Eric Aspengren ericaspen at gmail.com
Mon Jul 30 11:32:02 PDT 2012
So, I've got this PL/PGSQL script that doesn't want to work. I've got the
TIGER geocoder up and running and I can get whatever I want from that.
However, when I try and combine ST_Within with the output from GEOCODE I
get an error. I assume there's a simple syntax error here, but I can't
figure it out. I've been able to get this to work when just cutting and
pasting the actual geometry data into where "geocoded" is below, but
replacing it with the variable name gives me an error (sldu is a table with
Senate districts and sldust is the district number column):
CREATE OR REPLACE FUNCTION get_district(address text)
    RETURNS text AS
DECLARE
    district RECORD;
    geocoded RECORD;
BEGIN
    SELECT geomout into geocoded from geocode(address) as g;
    SELECT sldust from sldu into district where ST_Within(geocoded,
the_geom);
    return district;
END;
LANGUAGE 'plpgsql' IMMUTABLE;
geocoder=# select get_district('1700 C St Lincoln, NE');
ERROR:  function st_within(record, geometry) does not exist
LINE 1: SELECT sldust from sldu where ST_Within( $1 , the_geom)
HINT:  No function matches the given name and argument types. You might
need to add explicit type casts.
QUERY:  SELECT sldust from sldu where ST_Within( $1 , the_geom)
CONTEXT:  PL/pgSQL function "get_district" line 6 at SQL statement
Eric Aspengren
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120730/f6fe7942/attachment.html>
