[postgis-users] Help with PL/PGSQL!
Gregory Kramida algomorph at gmail.com
Mon Jul 30 12:04:42 PDT 2012
If you're sure you're in a database based on the PostGIS template, I'd
try putting the schema name in front of the function name, i.e.
"public.ST_Within(...", see if that's the issue.
-Greg Kramida
On 7/30/2012 2:32 PM, Eric Aspengren wrote:
> So, I've got this PL/PGSQL script that doesn't want to work. I've got
> the TIGER geocoder up and running and I can get whatever I want from
> that. However, when I try and combine ST_Within with the output from
> GEOCODE I get an error. I assume there's a simple syntax error here,
> but I can't figure it out. I've been able to get this to work when
> just cutting and pasting the actual geometry data into where
> "geocoded" is below, but replacing it with the variable name gives me
> an error (sldu is a table with Senate districts and sldust is the
> district number column):
> CREATE OR REPLACE FUNCTION get_district(address text)
>     RETURNS text AS
> DECLARE
>     district RECORD;
>     geocoded RECORD;
> BEGIN
>     SELECT geomout into geocoded from geocode(address) as g;
>     SELECT sldust from sldu into district where ST_Within(geocoded,
> the_geom);
>     return district;
> END;
> LANGUAGE 'plpgsql' IMMUTABLE;
> geocoder=# select get_district('1700 C St Lincoln, NE');
> ERROR:  function st_within(record, geometry) does not exist
> LINE 1: SELECT sldust from sldu where ST_Within( $1 , the_geom)
> HINT:  No function matches the given name and argument types. You
> might need to add explicit type casts.
> QUERY:  SELECT sldust from sldu where ST_Within( $1 , the_geom)
> CONTEXT:  PL/pgSQL function "get_district" line 6 at SQL statement
> Eric Aspengren
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120730/994137c5/attachment.html>
