[postgis-users] Help with PL/PGSQL!
David William Bitner
bitner at gyttja.org
Mon Jul 30 13:13:52 PDT 2012
You have geocoded declared as a type record. ST_Within needs that to be of
type geometry.
On Mon, Jul 30, 2012 at 1:32 PM, Eric Aspengren <ericaspen at gmail.com> wrote:
> So, I've got this PL/PGSQL script that doesn't want to work. I've got the
> TIGER geocoder up and running and I can get whatever I want from that.
> However, when I try and combine ST_Within with the output from GEOCODE I
> get an error. I assume there's a simple syntax error here, but I can't
> figure it out. I've been able to get this to work when just cutting and
> pasting the actual geometry data into where "geocoded" is below, but
> replacing it with the variable name gives me an error (sldu is a table with
> Senate districts and sldust is the district number column):
> CREATE OR REPLACE FUNCTION get_district(address text)
> RETURNS text AS
> DECLARE
> district RECORD;
> geocoded RECORD;
> BEGIN
> SELECT geomout into geocoded from geocode(address) as g;
> SELECT sldust from sldu into district where ST_Within(geocoded,
> the_geom);
> return district;
> END;
> LANGUAGE 'plpgsql' IMMUTABLE;
> geocoder=# select get_district('1700 C St Lincoln, NE');
> ERROR: function st_within(record, geometry) does not exist
> LINE 1: SELECT sldust from sldu where ST_Within( $1 , the_geom)
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts.
> QUERY: SELECT sldust from sldu where ST_Within( $1 , the_geom)
> CONTEXT: PL/pgSQL function "get_district" line 6 at SQL statement
> Eric Aspengren
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120730/be5dfd59/attachment.html>
