[postgis-users] PostGIS through xCode
Charlie Sharpsteen
charles.sharpsteen at gmail.com
Fri Jun 1 09:21:50 PDT 2012
On Friday, June 1, 2012 4:30:41 AM UTC-7, chris mollis wrote:
> Right.. using REST calls is the way to do that. You'll basically need to
> do any complex geo queries/functions in PostGIS and then return vectors of
> lon/lat points which you then display with the MapKit apis.
> On Fri, Jun 1, 2012 at 7:24 AM, Charles Galpin wrote:
>> Hi Ahmad
>> You won't connect to the database directly. Depending on what the data is
>> you can use a variety of methods. Simple REST style calls to a web server
>> which runs code to query the database and return the data could be
>> sufficient, but for anything more complex I suggest using a WMS server like
>> geoserver or mapserver.
>> If you want your app to run on multiple platforms consider doing it in
>> html 5.
>> hth
>> charles
CartoDB is also a good choice that is worth some investigation:
http://cartodb.com/
They do a great job of wrapping a web-accessible API around PostGIS tables.
The source code for the entire system is also freely available on
GitHub---but it does take a bit of work to unbox, configure and maintain by
yourself.
-Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120601/93d38bf4/attachment.html>
