[postgis-users] PostGIS through xCode
chris mollis
chris.mollis at gmail.com
Fri Jun 1 04:30:41 PDT 2012
Right.. using REST calls is the way to do that. You'll basically need to
do any complex geo queries/functions in PostGIS and then return vectors of
lon/lat points which you then display with the MapKit apis.
On Fri, Jun 1, 2012 at 7:24 AM, Charles Galpin <cgalpin at lhsw.com> wrote:
> Hi Ahmad
> You won't connect to the database directly. Depending on what the data is
> you can use a variety of methods. Simple REST style calls to a web server
> which runs code to query the database and return the data could be
> sufficient, but for anything more complex I suggest using a WMS server like
> geoserver or mapserver.
> If you want your app to run on multiple platforms consider doing it in
> html 5.
> hth
> charles
> On Jun 1, 2012, at 2:18 AM, Ahmad Aburizaiza wrote:
> Hello all,
> I am trying to build an iPhone app with a Google Map to display data
> stored on a remote PostGIS database. Anyone had such an experience. I need
> to know how to connect to the database so I can query the data.
> Thanx in advance
> Ahmad Aburizaiza
> PhD student at George Mason University
> Geography and Geoinformation Science Department
> Fairfax, VA, USA
> Tel : +1-703-981-0354*
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120601/fdd20748/attachment.html>
