[postgis-users] PostgreSQL/PostGIS x64 Error on PostGIS Install
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Jun 8 06:19:13 PDT 2012
On 07/06/12 14:00, Donald Kerr wrote:
> Thanks, Regina.
> After uninstalling, I tried a fresh install of PostgreSQL followed by a
> fresh install of PostGIS. The difference this time is that I did not use the
> existing data structure and started with a new one. The installation went
> well and without error.
> I uninstalled then repeated the above process with my existing data
> structure and got the same error as before. The data structure was created
> using the 32 bit version of PostgreSQL/PostGIS:
> postgresql-9.1.3-1-windows.exe (Not 9.1.4).
> Is there an incompatibility between 64 bit and 32 bit data structures? Any
> pointers appreciated.
Ah yes. Due to the different variable sizes between 64 and 32 bits, the
underlying binary structures on disk will be different and therefore
incompatible.
HTH,
Mark.
