[postgis-users] PostgreSQL/PostGIS x64 Error on PostGIS Install
Donald Kerr
donald.kerr at dkerr.co.uk
Fri Jun 8 06:26:05 PDT 2012
Ok, Mark, thanks for the confirmation.
I suppose then that I would have to dump the contents of the 32 bit setup
then import to the 64 bit setup which I'm assuming is possible. Offhand, do
you, or does anyone else, know if replication from 32 bit to 64 bit works?
What I'm trying to do is maintain one master data structure on a server
(currently 32 bit) and replicate to various clients; most are 32 bit but
I've just started experimenting with 64 bit clients. I haven't looked at 32
bit to 32 bit replication, never mind complicating matters with 64 bit, as
yet but it's on the To Do list.
Many thanks.
Regards,
Donald
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: 08 June 2012 14:19
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL/PostGIS x64 Error on PostGIS Install
On 07/06/12 14:00, Donald Kerr wrote:
> Thanks, Regina.
> After uninstalling, I tried a fresh install of PostgreSQL followed by
> a fresh install of PostGIS. The difference this time is that I did not
> use the existing data structure and started with a new one. The
> installation went well and without error.
> I uninstalled then repeated the above process with my existing data
> structure and got the same error as before. The data structure was
> created using the 32 bit version of PostgreSQL/PostGIS:
> postgresql-9.1.3-1-windows.exe (Not 9.1.4).
> Is there an incompatibility between 64 bit and 32 bit data structures?
> Any pointers appreciated.
Ah yes. Due to the different variable sizes between 64 and 32 bits, the
underlying binary structures on disk will be different and therefore
incompatible.
HTH,
Mark.
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
