[postgis-users] How to use dimension(geometry) command
José María Amuedo jmamuedo at gmail.com
Mon Jun 18 02:36:32 PDT 2012
I meant dimension(geometry) to know if my consulted data is 2D or 3D.
I found in the oficial documentation that if you use dimension(geometry)
you get 2 for 2D or 3 for 3D data.
Do you know something about this?
Thanks,
José María
2012/6/18 Nicolas Ribot <nicolas.ribot at gmail.com>
> Hi, you mean st_dimension ?
> select st_dimension(geom). Returns 0 for points, 1 for linestrings, 2
> for polygons.
> Nicolas
> On 18 June 2012 09:37, José María Amuedo <jmamuedo at gmail.com> wrote:
> > Hello,
> > I would like to know how can use the dimension(geometry) command.
> > Thanks,
> > Jose María
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120618/c528c828/attachment.html>
