[postgis-users] How to use dimension(geometry) command
Greg Polanski
polanski.greg at yahoo.com
Mon Jun 18 02:54:25 PDT 2012
ST_CoordDim(geometry) gives 2 for 2D coordinates, 3 for 3D coordinates.
If you want to use old commands like "dimension" with a recent postgis version, you have to run legacy.sql that comes with your postgis installation. But note the st_dimension and st_coorddim are different things!
Greg
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Monday, June 18, 2012 11:36 AM
Subject: Re: [postgis-users] How to use dimension(geometry) command
I meant dimension(geometry) to know if my consulted data is 2D or 3D.
I found in the oficial documentation that if you use dimension(geometry) you get 2 for 2D or 3 for 3D data.
Do you know something about this?
Thanks,
José María
2012/6/18 Nicolas Ribot <nicolas.ribot at gmail.com>
Hi, you mean st_dimension ?
>select st_dimension(geom). Returns 0 for points, 1 for linestrings, 2
>for polygons.
>Nicolas
>On 18 June 2012 09:37, José María Amuedo <jmamuedo at gmail.com> wrote:
>> Hello,
>> I would like to know how can use the dimension(geometry) command.
>> Thanks,
>> Jose María
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120618/c3e0d3a8/attachment.html>
