[postgis-users] Minimum Bounding Rectangle
Paragon Corporation
lr at pcorp.us
Mon Jun 18 10:28:23 PDT 2012
It's on my todo. well first step of my todo anyway.
http://trac.osgeo.org/postgis/ticket/1332
Brent -- thinking of your idea
Have you tried using ST_LongestLine?
http://www.postgis.org/documentation/manual-svn/ST_LongestLine.html
I'm hoping to get back to this ticket soon but tied up with other things.
Thanks,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Brent Fraser
> Sent: Monday, June 18, 2012 12:37 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Minimum Bounding Rectangle
> Madison,
> I went looking a few months ago, but could find nothing.
> I wrote some PHP to:
> 1. Find the length of the polygon (vertices farthest apart)
> 2. Find the width (based on vertices farthest from length line)
> 3. Build bounding box using length (with angle of the the length
> line) and the width
> I'm still pondering the result when the input polygon is a square...
> But there should really be something like a
> "ST_ExtentRotated" or "ST_RotatedBBox" function in PostGIS.
> Best Regards,
> Brent Fraser
> On 6/15/2012 2:03 PM, Madison Shaw wrote:
> > Hi,
> > I was wondering if any one could possibly offer some advice.
> > I am wanting to calculate the area for a minimum bounding rectangle
> > for individual polygon features. I know I can use st_envelope or
> > st_extent along with st_area but this doesn't quite give me the
> > results I am after.
> > For example if the polygon was already a rectangle but was
> orientated
> > on an angle the bounding box area is much larger than the
> area of the
> > original rectangle, whereas I would like it to be the same
> value. I
> > suppose what I am after is a convex hull but as a
> rectangle. Is this
> > possible?
> > Any help is greatly appreciated.
> > Cheers
> > Madison
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
