[postgis-users] Create topologic layers from simple geometries
Sandro Santilli strk at keybit.net
Wed Jun 20 04:49:15 PDT 2012
It looks like you need to quote "Land_cover" in the INSERT statement.
PS: please copy & paste the queries and error messages inline as text,
    it's easier to read than screenshots.
--strk;
 Sent from our free software
 http://www.gnu.org/philosophy/free-sw.html
On Wed, Jun 20, 2012 at 11:17:04AM +0200, lcelati at latitude-geosystems.com wrote:
> Hello,
> Regarding a big project in Cameroon, i'm testing topology in Postgis. I
> have created a db called "Test_Cameroun". I have already import simple
> geometries into two tables called "land cover" (MULTYPOLYGONN) and
> "network"(MULTILINES).
> These two tables are localised into public schema.
> I want to create topologic layers from these simple geometries. I have
> created a new topology schema (create topology) called "topology_test"
> successfully.
> Then, I read the example written on toTopoGeom postgis page:
> http://postgis.refractions.net/documentation/manual-2.0/toTopoGeom.html
> That's why i have created a new table called for instance "nei_topo"
> always in public schema :
> CREATE TABLE nei_topo(gid serial primary key, nei varchar(30));
> Then,
> I added to it a topogeometry column
> SELECT topology.AddTopoGeometryColumn('topology_test', 'public',
> 'nei_topo', 'topo', 'MULTIPOLYGON') As new_layer_id;
> Then,I want to populating the new topogeometry column via use new layer id.
> INSERT INTO nei_topo(nei, topo)
> SELECT nei,  topology.toTopoGeom(geom, 'topo_cameroun', 1)
> FROM Land_cover
> WHERE gid BETWEEN 1 and 8;
> But i have a error message.
> I send you by attachment all screen shots.
> Could you throw light for me ASAP please.
> Kind regards.
> Laurent Celati.
> Laurent Celati - Geospatial applications specialist - LATITUDE GEOSYSTEMS
> 47, avenue de la Division Leclerc - 95170 Deuil-la-Barre, FRANCE
> Tel : + 33 (0)1 34 17 23 84 - Fax : + 33 (0) 1 39 64 04 86
> mob : + 33 (0)6 xx xx xx xx
> skype lcelati
> E-mail : lcelati at latitude-geosystems.com
> http://www.latitude-geosystems.com
> ----- Fin du message transféré -----
