[postgis-users] Topology performance test
Stefano Iacovella
stefano.iacovella at gmail.com
Thu Jun 21 09:12:15 PDT 2012
2012/6/21 Sandro Santilli <strk at keybit.net>:
> On Thu, Jun 21, 2012 at 09:29:39PM +1000, Luca Morandini wrote:
>> On 06/21/2012 07:45 PM, Sandro Santilli wrote:
>> >... I suspect /usr/local/lib/libgeos_c.so != /usr/local/lib/libgeos_c.so.1
>> Indeed, but let me show you the outputs of what you requested:
>> ldd /usr/local/lib/libgeos_c.so.1
>> linux-vdso.so.1 => (0x00007fff7587d000)
>> libgeos-3.3.3.so => /usr/local/lib/libgeos-3.3.3.so (0x00007f058cdad000)
>> libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f058ca99000)
>> libm.so.6 => /lib/libm.so.6 (0x00007f058c815000)
>> libc.so.6 => /lib/libc.so.6 (0x00007f058c492000)
>> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007f058c27b000)
>> /lib64/ld-linux-x86-64.so.2 (0x00007f058d37e000)
>> ls -l /usr/local/lib/libgeos_c.so
>> lrwxrwxrwx 1 root root 18 2012-06-21 09:18
>> /usr/local/lib/libgeos_c.so -> libgeos_c.so.1.7.3
>> ls -l /usr/local/lib/libgeos_c.so.1lrwxrwxrwx 1 root root 18
>> 2012-06-21 09:18 /usr/local/lib/libgeos_c.so.1 -> libgeos_c.so.1.7.4
>> I guess it boils down to this: I can I get rid of 3.3.3 ?
> You can surely get rid of 3.3.3 by running "make uninstall" from its
> build tree, or by manually dropping libgeos_c.so.1.7.3. But you can
> probably also just re-link libgeos_c.so.1 to libgeos_c.so.1.7.4
Sandro, I run
$:~/sources/geos-3.3.3$sudo make uninstall
then
stefano at ubuntu1204vm:~/sources/geos-3.3.3$ ll /usr/local/lib/
total 18720
drwxr-xr-x 5 root root 4096 Jun 21 18:05 ./
drwxr-xr-x 11 root root 4096 May 2 14:38 ../
drwxr-xr-x 2 root root 4096 Apr 27 16:10 geos/
-rwxr-xr-x 1 root root 15504429 Apr 27 16:10 libgeos-3.3.3.so*
-rwxr-xr-x 1 root root 866246 Apr 27 16:10 libgeos_c.so.1.7.4*
-rw-r--r-- 1 root root 1695394 Apr 27 16:21 libproj.a
-rwxr-xr-x 1 root root 919 Apr 27 16:21 libproj.la*
lrwxrwxrwx 1 root root 16 Apr 27 16:21 libproj.so -> libproj.so.0.7.0*
lrwxrwxrwx 1 root root 16 Apr 27 16:21 libproj.so.0 -> libproj.so.0.7.0*
-rwxr-xr-x 1 root root 1070954 Apr 27 16:21 libproj.so.0.7.0*
drwxr-xr-x 2 root root 4096 Apr 27 16:21 pkgconfig/
drwxrwsr-x 4 root staff 4096 Apr 27 10:08 python2.7/
Should "make uninstall" delete the two libgeos file?
It is safe if I delete them and then install geos-3.3.4?
Cheers
Stefano
> I'm surprised this isn't done by 'ldconfig' itself (did you run that
> after installing geos ?)
