[postgis-users] Topology performance test
Sandro Santilli strk at keybit.net
Thu Jun 21 14:02:08 PDT 2012
On Thu, Jun 21, 2012 at 06:12:15PM +0200, Stefano Iacovella wrote:
> Sandro, I run
>  $:~/sources/geos-3.3.3$sudo make uninstall
> then
> stefano at ubuntu1204vm:~/sources/geos-3.3.3$ ll /usr/local/lib/
> drwxr-xr-x  2 root root      4096 Apr 27 16:10 geos/
> -rwxr-xr-x  1 root root  15504429 Apr 27 16:10 libgeos-3.3.3.so*
> -rwxr-xr-x  1 root root    866246 Apr 27 16:10 libgeos_c.so.1.7.4*
> Should "make uninstall" delete the two libgeos file?
Unless you configured the build to have a different prefix.
> It is safe if I delete them and then install geos-3.3.4?
Yes.
--strk;
